Heater weirdness 1.3 VVTI
Baldcoot
Hi folks got an odd 1 for you. Heater on ,fan works fine, up the screen loverly hot air .But aim at your legs or feet freezing cold air comes out.
And at the minute this isn't fun at all and the wife is ready to kick off if I don't fix it.
If you "split "direction same problem warm upwards but cold down to your feet Help.
Edited by Baldcoot
Forgot to turn notifications on
Well sorted now,you tube is my friend .Found the in out hoses for the Heater matrix and gave it a cold water flush out .It was blocked but 10 minutes of flow/return started it running through easily ,top up with 50/50 antifreeze and warm feet return ..
I gave you a 'thanks' for reporting back with your fix, great for the library. 🙂
Yes and even more important his wife is a happy warm footed lady🚗👍
