How to turn off/on recirculation when the engine is off
Skippy_77
As winter is now here in the UK, i can not turn on re-circulation so the air outside air vent is off to stop cold air from coming in over night.
I'm finding now inside the windscreen is now frosting up as well as the outside
Can you advise how to turn this feature off and on so in the winter outside air does not cause the frost to build up in side the windscreen.
I used to be able to hold the re-circulation button in for 10 or so seconds and it would keep.  But once the ignition is off I think this re-opens again.
Any advise that doesn't require visiting a dealership would be great.
Manual air con or climate control?
Frost on the inside of the windscreen is caused by moisture already inside the car condensing and freezing on the cold glass. Switching to recirc will likely make the problem worse rather than better.
I've noticed in my Auris that a short time (a few minutes) after turning the ignition off I can hear 'something' in the heater area operate... it sounds just like a flap being operated via its servo motor and I've always assumed it is the air recirculation flap closing to stop outside air entering.
before you get home turn the heating temperature down to lower the chance
of having condensation forming inside the car, the hotter your car the more chance
of condensation with the difference between inside & outside temperatures
I can hear this flaps moving too. I don’t think it’s the recirculating flap though as my one for now never changes , it stays the way I set. (Always from outside) in summer when I use AC stays in recirculating mode. I believe the flaps that move are something else, something about the temp perhaps.
