Selector design specs for 4 speed column shift 1977 HiAce h10
Need help the selector broke at the gearbox end on 1977 HiAce I presume with the 12r motor it seems to have 2 selectors 1st and 2nd gear are fine no 3rd or 4th and can manually put into reverse from the gearbox why does it have two seperate selectors and is there an easy fix as unable to find a replacement part and the part is quite pitted and is cast iron so don't reckon I can weld it up. Thanks for reading this
