Hi guys
My wife recently bought a CH-R from a local dealer with the expectation of it having sat nav built in.. Unfortunately this is not the case now we've been informed its going to cost £980 to install it.. From what I can make out this is just a software installation no hardware needed has anyone had experience of this or am I being given the run around
There is a sat nav module that needs to be added - so there is hardware. Plus presumably a GPS aerial, etc.
If you press the nav button and get a system bot installed massage you need hardware see HERE
