Hello, I recently bought my first Toyota. I got a 2016 Corolla L and I am trying to see if there are any aftermarket company that specializes in Toyota? I am currently trying to replace my engine and transmission drain plugs with magnetic ones and look up any small modifications that I can do.
hi seth if you do regular oil changes using the correct oil for your model you wont need to use magnetic plugs mate, but they are so cheap that if you are determined to use them there are quite a few on eBay for around a £5, or you could stick a magnet on the outside of the sump that will collect small particles.
