Tsport Phase 2 are they same as the Phase 1?
Chopsy
Anyone know if the phase 1 Yaris Tsport has the same door as he phase 2 yaris Tsport hinge wise etc?
Mine is a JT chasis Phase 1. Was the Phase 2 made in France?
Just don't want to get a O/S door for it not to fit.
Any help appreciated.
iirc The only difference is the facelift 2003-2005, the car is the same body wise as a base model
if it is a JT car you need a door from another JT car as there can be some minor differences
Thanks for the reply. We found the chasis no. on the bonnet and its a JTD chasis phase 2, so it looks like it should be ok.
Plot twist - turns out the phase 1 door hinge inside distance - around 28cm the phase 2 door hinge distance 27cm.
I was told this could be an issue by the body shop, well still on the lookout for an O/S door for a Phase 1 Tsport.
From my experience not an issue I've swapped them before
