Is this from my car?!
Manwell1
Hi there,
I am hoping someone can help me! I drive mark 2 Yaris today while driving to work while overtaking I got completely blinded by spray and the next thing I know I start to hear a scraping sound under the car. I got to work and had a look and the bit of metal below was hanging under my car. It was sort of wrapped around the exhaust but came away quite easily. Is this my heat shield, or could it be from someone else's car. I can't see under the car to check if mine is still intact. Any ideas would be appreciated!  Thank you in advance. Laura
Ah nuts, thank you though best to know I guess. Will take it to the mechanic. The link to the picture doesn't seem to work owever, any chance of posting direct?
Edit: Nope, don't worry I got it now. Thank you again
Yeap, mechanic can eventually put it back but he will need to use extra large washer to secure or may advise you to buy a new one. See the red circles on the picture, it’s been damaged, should be usually just a hole in the the corners.
