Engine fault warning light
Hi
Yesterday I tried to remove my spark plugs to clean/check the gap. I couldn't remove the plugs as I didnt have a tool long enough to twist them out. I put the coils back on and the filter cover, i now have the engine fault warning light on. Can somebody explain what this might be caused by. Thanks
Hi, you will need to diagnose the fault code first then you start from there. There is a possibility you did something to the plug, coil or did not connect properly either of these. Double check the job you have done, and run a diagnostic. Carista obd 2 very good device for that work.
Regards
Hi
Thanks for the reply, I will revisit this once the snow has gone.👍
