Upgrading rear tail lights to facelift ones? (MK1)
Hi all,
Bought a '07 Aygo needed to change a rear bulb and discovered the lens/casing is basically held on by silicone and the wire connector.
My question is can I upgrade from my current https://www.ebay.co.uk/itm/Toyota-Aygo-2005-To-2012-N-S-Left-Passengers-Rear-Light-815610H010-5-Door-/352515167366?_trksid=p2349624.m46890.l4929
To
https://www.ebay.co.uk/itm/Toyota-Aygo-WNB1-KGB1-1-0-Rear-Light-Left-/174615661571?_trksid=p2349624.m46890.l49292
Mainly I can't tell if the newer style ones have the reverse light (NSR) at the bottom with the fog light being on the OSR and wanted to confirm before I commit. Id rather not have to faff about with wiring.
the facelift lights will fit, but not the one you have linked to. That one is coming from Germany and so the fog/reverse light is swapped.
They are the facelift lights (12/2008 - 2014) available in RHD
81551-0H080
81561-0H080
the reverse light is red but when in reverse they turn white
20161219_115221.jpg.378aa4d00638eba1231a
