Fast clicking noise when neutral on 2017 avensis manual gearbox
tadelis007
Can anyone suggest me what could cause fast clicking noise (only can hear from inside the car) seems like coming from gearbox (manual), only on neutral gear, and gear knob also vibrating and clickering on neutral, once touch a speed pedal it’s gone, no clicking noice once on gear and speeding, and no difference, same clicking noise-neutral on gears or with the clutch pedal depressed, and it’s only done 53000 miles, 2017 2l d4d avensis
any suggestions appreciated
Had a similar fault traced to the clutch on the air-conditioning unit try and engage air con when idling and see if it does away.
As a 2017 UK car with 53k on the clock it should still be under the Toyota 5 year warranty?
