Front windscreen washer fluid not delivered along wiper blade but spurting out at base of arm
Inneedofhelp
Frozen nozzles or rubber washer solution supply tube popped off where it connects to nozzles.
I would just suggest the the pipe on the wiper arm has frozen and maybe caused a pipe to split or a joint pulled loose
Thank you both Stevecrvn and fordulike....appreciate your quick responses....
  • 11 months later...
Did you fix this as ours has started doing this?
