Navigation system not available
Milence992
I recent purchased a Toyata hilix city plus 2020 and it says Navigation not available. But on site says that have multimedia Toyota Touch 2 with Go navigation system. I dont understand do i need to update firmware?
Split into new topic and moved to the Hilux club.
What site are you looking at? Did you buy the vehicle from a dealer or elsewhere?
If it says that navigation isn't available, that is probably because the multimedia unit hasn't got the sat nav module installed. Not firmware.
https://www.toyota.rs/new-cars/hilux/oprema-i-specifikacije/grade=2412b285-3238-4879-9035-954f86dbaf53|bodytype=f880e881-f794-4aef-9e12-db540db6d76d
From a dealer.
Might suggest the website has the 2021 spec Hilux, whereas your profile states you have a 2020. Check either with your Toyota dealer or your Toyota importer.
I would suspect the "Go" Navigation box is not installed. Go back to who you bought it off to confirm
