RSA audible warning not working
Martyn29
I have just bought a Yaris 2019/2020. The RSA is working but the audio is not. I have turned on the audio warning in settings and its fine. But when I restart the car the audio is turned off again. Is this standard or is there a way to keep the audio on as default please
Edited by Martyn29
Spelling error
Moved to the Yaris club.
What model Yaris do you have:
Mk3 2011-2020
Image result for 2019 yaris
Mk4 2020>
Image result for 2020 yaris
7 minutes ago, Martyn29 said:
A mk4
OK
There is a Technical service bulletin from Toyota for this:
BE-00515T-TME
Subject: RSA Over speed warning setting is lost after the IG cycle
All Markets
Models – Model Codes: Yaris - KSP211, MXPA11, MXPH11 ;
Description of the phenomenon Some customers may experience and report "Over speed warning setting is lost after the ignition cycle".
As additional information, customer can set the over speed warning at 2 or 5 km/h. Over speed warning can be 1. Visual 2. Audio or 3. Combination of Visual & Audio.
Production change Counter measure software has been applied in mass production
Repair Procedure - Reprogramming Reprogram the “FORWARD RECOGNITION CAMERA SENSOR REPROGRAMMING.” to the latest available calibration ID
Does this mean I have to take it in to get reprogrammed. I've only had it a week and it's new
PM your chassis number and I can check build dates
Yes you will need to visit your dealer for an update the fix was introduced into production from 10th Dec 2020 yours was built 2nd Nov 2020
