Starter problems
Wizal26
2010 Yaris 1.4 diesel multi mode starting problems when you turn the key the starter turns but doesn’t  engage straight away just spins then turns after a couple of seconds
The solenoid is dying = Replace the starter
If you can avoid the lower end reman starters, A brand new Denso unit is just over £200 if you can find one
