Maintenance mode for Toyota Yaris 2020 4th generation
RaulYaris
I succesfully tested generic toyota maintenance mode into my new Yaris 2020 4th generation:
1.  Press the start button twice
2.  Depress the accelerator two times fully
3.  Put the vehicle in neutral (press the brake pedal)
4.  Depress the accelerator two times fully
5.  Put the vehicle back into park (press the brake pedal)
6.  Depress the accelerator two times fully
7.  Depress the brake pedal and press the Start button
The engine will immediately start to idle and will do so until you turn off the car.
Best regards.
R.
  • Like 3
  • 2 years later...
Hello Raul,
Do you know if this will work on the MK3 2014 too? I cannot test it right now hence asking but I can give it a try at a later point.
Many thanks,
Dave
1 hour ago, inteli7 said:
Hello Raul,
Many thanks,
Dave
yes it will work on all Toyota hybrids. This is the procedure prior to oil change. If the engine is cold.
That's how Voodoo, and other mysterious things happen.
  • Haha 2
On 10/2/2023 at 7:57 PM, TonyHSD said:
Ah, nice. I didn't really know that but I can confirm that it works. (did try it in the end)
Thank you 🙂
Thank you 🙂
You are welcome.
