Avensis T25 1.8 - what is this?
sproutdreamer
In the engine compartment behind the engine a black plastic container with pipes in and out. I had alway assumed without looking closely that it was a fuel filter but now I look closer it is not. Is it some sort of emission control gizmo?
If looks like this one on the picture is charcoal canister for fuel vapour, part of the fuel supply system. Maintenance free usually, but there is information that if you regularly overfill your tank that part gets damaged and it’s not cheap to replace if you buying new one. 👍
Hi Tony - yes that is it. I was unaware that overfilling was an issue, thanks
