2010 Estate (T27) Rear Light Cluster Removal
akibn
Hi everyone,
I very recently bought a used T27 estate and it's fantastic, super practical and good to drive.
The biggest gripe I have with it is that the rear light lens is damaged as shown in the picture. The plan was to remove the whole cluster and either:
- Clean the lens, remove any moisture and glue it back together (not sure if this is possible as sometimes these clusters are all in one)
or
- Replace with a new unit
I can buy a replacement for about £80 so I would prefer the first option to save money however it seems near impossible to remove the light cluster in the first place. I have searched online but not found much of use; apparently there are three bolts to unscrew however I think I have to remove the carpet lining in the boot first because the hatch to change the bulbs is quite small and I can only see one of the bolts.
Does anyone have any tips/advice about removing the rear light cluster?
Thank you for reading!
  • 1 year later...
  • 7 months later...
I have a boot water leak, anyone know how to replace the gasket on the rear light cluster.
