Hello!
I have a 95 previa that has a parasitic draw. I’ve tested every fuse in the dash and in the engine compartment. None of the fuses affect the draw when removed. Have you run into this? Is there another fuse box other than the one under the center of the dash and the one on the right side of the engine compartment?
     Thanks!
Moved to the Estima forum.
Do you have a dash cam?
