Turbo passing oil D4D
BolkowBob
I have a 2002 Rav 4 d4d.
Recently replaced turbo core, last one hade a major fail. All went back together ok but I now have oil passing the turbo seals, definitely on the air side and I think also on the exhaust side.
Did all the usual clean up and oil/filter changes, cleaned out the sump pan and blew out the turbo return line.
Getting a fairly rapid increase in breather pressure from the top end so I am wondering if its ring blow-by or leaking injector seals. Had a look at injectors with TIS and see two are slightly positive and two negative on displacement at idle, is this a clue?
All comments welcome...help!!
