disassemble a headlight unit
Felixguzzi
Hay, does anyone know how to disassemble a headlight unit, what needs to be loosened?
If you mean, disassembling it into pieces, i doubt it's gonna go without the use of some force.
Once the headlight is assembled in the factory, they usually glue the front and back pieces together, to prevent water getting in.
No sorry, I mean get it out of the car in one piece. The problem is that I want to change the bulb but it can't be removed, it's like she's turning crazy. Then I can better see what is wrong and it is also easier to work. My first impression is that the plug connection has been disconnected from the bayonet closure, the three ridges.
I think you need to remove the bumper to be able to take the headlights out.
