Key remote on my Avensis
Devonlad1966
Hi Folks.  Please would you recommend where I can get my key remote fixed on my advensis 2002.  The unlock button is not working.  When I take it apart there is a little button behind the rubber that has come away from the circuit board.
Hi Devon lad 1966. I had this same problem. Assume that you have the 2-button keyfob. I went on line and found a place in Lancaster that sells the buttons and the rubber pad that covers them. The pad is for the 3-button fob but you just cut the not-required one off. It is much better than the individual rubber covers. They cost less £3 about 8-years ago. You just need to find somebody who is able to "de-solder and solder" the parts.
Hope this helps. Bill
