Multimedia for Toyota Avensis 2012
me2Online
I am looking to replace the car's  original multimedia  device with an aftermarket device such as this one:
https://www.aliexpress.com/item/4000925390945.html?spm=a2g0s.8937460.0.0.22062e0ePxfUA5
I have looked a several devices. They all come with a "plug and play" harness to connect the device to the car's cables.
The harness connectors look like this
The marked female sockets accepts 20 pins plug, but the car does not have a 20 pins cable:
Also the usb cable (marked #6 in the image) does not fit the harness nor the device.
What am I missing ?
One more comment:
The marked 20 pins connector does not have a matching cable in the car
AND
the car cable marked as #3 (16 pins) does not have a matching connector in the harness.
Don't waste your money on rubbish from aliexpress stick with the name brands
1st pic is harness for a later car / different model
to use the factory usb you will need an adapter
Thank you flash22.
I will get an adapter for the usb.
According to the feedback I read the harness should fit the model. I just do not understand how.
I had Aliexpress android headunit in E12 Corolla. Sound quality was pretty poor. 2GB ram memory isn't enough. I had 4GB and it was still pretty slow. Now i have T27 Avensis and i upgraded my headunit to original touch&go headunit (59005) and it cost about same than Aliexpress headunit.
Thanks for the tips  JiiN. Where did you get such a low cost Touch and Go device from ?
I ordered it from https://rrr.lt/en . Second hand headunit from a wrecked car but it was like new! I picked headunit with connectors in it, so the soldering and installation was really simple. They answered almost immediately to my questions and everything worked like a charm. I was lucky and found also gps antenna from same company where my headunit came from. It didn't took even a week to get package here in Finland. Here is more about upgrading a headunit:
I have now this: https://rrr.lt/en/used-part/rag52640-8614005010-toyota-avensis-t270-radio-cd-dvd-gps-head-unit in my car.
Oh, and my T27 is 2010 if it matters.
Thanks. That is very useful information. I have the same device om my T27 2012.
