Fog light switch
hafnia
Hi, my 2012 yaris P13 comes prewired with cables for the fog lights, i have installed the fog lights themselves, but i have no idea where the cable runs for the switch? Its a button type, and it seems to be a 5 pin.
What country are you in ? Most xp130's have the fog lights on the stalk, i take it you have fitted the relay and fuse(s)
Denmark, but you are correct in the stalk, its way easier to purchase a stalk stalk with the fog light switch on it, if your car is pre-wired from the factory which is what i have bought instead.
If your car was wired from the factory you need to add the stalk, relay and fuse(s)
or did you buy a fog light kit with its own wiring ?
Ah, looks like i need relays and fuses the , and yes, it came with it on wiring
