Erratic automatic transmission gear change after Front CV axle change
2010 Corolla, South African assembled model: Replaced forward cv axle shafts. Ended up with erratic automatic transmission gear change in Drive. Change from 1 to 2 - slightly rough, 2-3 awful with skip and engine revving to 5000rpm before change. Transmission oil is satisfactory and right level. Why would just changing a mechanical component result in this awful situation
Hi, why needed to change the cv axle and have you changed with original one or aftermarket?
I changed with original cv axles
Sounds like the car is struggling, so it revs up to higher RPM before switching.
jack up the car, and try to spin the wheel by hand, see if it moves without resistance.
I did that and it moves with zero resistance
Did you get the correct drive shaft(s) for the car ? Does the car have abs ? i would check the data from the wheel speed sensors with a scan tool as the TCM uses the wheel speed and rpm to know when to shift
That is what is being done today. Was out of town for a while and i just parked the vehicle. Will post outcome once finished. Many thanks all
The car has ABS and i got the correct cv shaft
It's more than likely a bad abs ring on a wheel bearing
