OBD2 scanner recommendations.
Swerve74
OBD2 scanner recommendations. Not fortune's. Something that can measure engine water temperature etc.
The worlds your lobster, do you have a budget in mind ??
Creader and Autel are good for the money or do you want something Toyota specific ?
Can either of those diagnose an abs fault? and clear codes?
It's the same as Carly, it's a generic Elm327 abite some firmware tweaks
