Hi everyone.  Pete the newbie here!!  I have had my Lucida for ten years now, and never had to do any work to the brakes in all that time - until now!  The rear shoes are very worn, and the cylinders have had to be cut off in order to detach the brake pipes - unbelievably rusty, so all to be renewed.  Therein lies my problem.  My local supplier cannot find ANY brake parts for my vehicle, as it is all done by registration on his system, and either the car is too old, or it's because it is a 'grey' import.  So can anyone help?  I need rear brake shoes, cylinders, and flexipipes.  The pipes would be fairly standard, I would imagine, just depending on length, but the shoes and cylinders will need to be compatible, maybe from another model. perhaps??  I hope someone on here can help!!
Hello Pete  - welcome to Toyota Owners Club.
Moved to the Estima forum.
Might be worth having a word with Gary @ GT Motors, Newton Abbot, Devon.....he knows these vehicles well and might be able to give some advice.
http://www.gtmotors.co.uk/index.php
PM me your Vin/frame number, so we can cross-reference from the oem numbers
Cheers for that, my friend.
Hi there.  Thanks for coming to my rescue!!  Whereabouts will I find the number on the vehicle, as the one printed in the V5 doesn't seem to be correct - it's printed the same number as the engine number!  Putting this number into part search engines comes up "invalid" VIN.
Japanese domestic market vehicles don't have VINs, they have frame numbers. This is why, when you put the number into a website asking for the VIN, the site shows 'invalid VIN'.
Try the inside of the nearside wing...that's where mine is on my Estima.
A frame number starts with 3 letters then 2 numbers then 1 letter
eg. CXR20G-1234567
I have access to the full parts catalogue just PM me
As for location the plate is on the inner wing on the passenger side it may also be stamped by the front of the driver's seat (under a carpet flap) or on a sticker on the passenger door post
eg. CXR20G-1234567
The V5 says CXR - 0006866.
And it's wrong!!  I've got the correct number - will message you.
If the frame number is wrong on the V5C, it won't be DVLA's fault but the person who completed the documentation to register the car in the UK - presumably the person or company that imported it into the UK.
Yep, I reckon.  The two numbers after the initial three letters are missing!  I've got the correct one off the car.
Built - 09/1992
Model - CXR11G-RFSGX
Engine - 3CT
Rear shoes - 04495-35131 - BluePrint ADT34164
Cylinder seal kit - 04906-30100
or
Complete Cylinder - 47550-28020 - BluePrint ADT34453  FERODO FHW4241)
Drums - 42431-28050 - BluePrint ADT34714
12 hours ago, flash22 said:
Built - 09/1992
Engine - 3CT
or
Brilliant, thanks ever so much.  Do you know the number for the brake flexipipes, by any chance?
There are 2 type listed, a standard straight pipe that uses a fix line to the cylinder and a banjo type (what looks like it's for disc brakes)
they are also handed,
RH - 90947-02712
LH - 90947-02622
Look to be discontinued by BluePrint - you may have to get them made to order by the likes of Piratek or a Goodridge supplier
Edit. According to the spec of the cylinder the thread size is M10x1
Found the BluePrint number
RH - 90947-02712 - ADT353307
LH - 90947-02622 - ADT353170
Oddly ADT353170 comes back as left and right, so from what i can make out the oem part numbers are for different lengths
RH - 90947-02712
LH - 90947-02622
Cheers, very helpful.  There's a Hydraquip near me who may be able to put these together.
