Radiator
Degsymac
Just got an 02 rav it’s ace but at what point should the fans come on facin the radiator there are two ?? TIA x
The outside air temperature is probably too low right now and it may never come on.
Have you changed the coolant? New coolant will have a better temp coefficient than old contaminated coolant. Is it the correct mix? Is the hood shut? Is the heater on or off? All factors.
Okaydoke thanks I thought maybe there was a certain temp it was supposed to kick thanks
