1nz-fe cvt flywheel
salmanghiyas
Hello Community,
1: Can someone please share what is the weight of stock 1nz-fe cvt flywheel?
2: Can it be replaced by an aftermarket light weight one?
3: Which one? Any recommendations?
4: How much performance gain would be expected?
On a Hybrid ? The hybrid uses the 1NZ-FXE that uses the Atkinson cycle it is an eco engine, so there are no gain to be had
1NZ-FE CVT will have flex plate
How many places have you cut and pasted this question to ?
First of, if I wanted to ask about a Hybrid I would have already mentioned 1NZ-FXE but since I didn't and I categorically mentioned 1NZ-FE CVT so there was no reason boosting your post count by irrelevant posts.
And you never answered any of my questions either
And I didn't cut paste, I copy pasted this query to different forums because haven't got the appropriate answer yet, is there any problem in this? Seeking for answers?
I have already answered your question, the CVT uses a flex plate not A Flywheel
Thank you!
Can it be lightened? (the OEM one)
Or are there any aftermarket light weight flex plates available? If yes then which ones recommended
Please cease the squabbling or the topic will be hidden from view.
Sorry, I couldn't get you
