No Dab Signal
Ray Morris5239
Hi I have bought a 2017 Toyota Auris.  It had a basic radio with fm and am and a cd player only.  I bought a radio for it which has am/fm dab and sat nav.  Unfortunately I cannot get a signal for the dab stations, everything else works ok.  Do I need to get a new aerial, has anyone got any ideas.
What about antenna? If only FM one, Dab will not work.
  • 2 months later...
Sounds like you will need a DAB antenna fitting to that new head-unit. A standard car co-ax cable and aerial will pick up FM and AM without an issue. It will not pickup DAB though. Totally different frequency range. I believe DAB aerials normally go around the windscreen too (well, they did on my old car anyway) and the one that’s normally on the roof is for FM / AM.
