Toyota corolla versa diesel engine warning light
Hi.
I have a toyota versa 2006 2.2 diesel. I've had the car for about 6 months and the range engine warning light comes on and vcs and trs off warning lights. I've replaced the dpf and the exhaust agr valve and had all the air inlet manifold cleaned but lights keep coming on.
The local toyota garage don't seem able to fix.
Has anyone else had this issue and any advice on the root cause?
  • 4 months later...
My warning light came on on my 2006 2.2 diesel. Shortly afterwards I lost a lot of power.
It turned out to be a turbo hose which must have been leaking, which then blew. A replacement hose fixed it, no engine warning light after the repair.
What is the fault code present when the lights come on?
I didn't get the fault codes checked before it went in for the turbo hose replacement.
