Unknown grey screw caps
h2o
Whereabouts in the car were they found?
They are for the air-con check points under the bonnet. I know at least one is on the bulkhead. Other one probably on the line from the air-con pump.
One says L = Low and the other H = High and are knurled
An edumacated Guess, They are the caps from the High and Low pressure AC valves under the bonnet
