Verso 2016 how to remove the stereo head unit for repair
New member here so hope this is the right place to post. I have a 2016 Verso and the screen on my touch screen on the stereo is broken and needs to be repaired. I have found someone who can hopefully repair it but they are not local and I have no idea how to get the head unit out. Can anyone help please? I have trawled YouTube but have come up blank so far. Pic attached for reference.
Thanks 🙂
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwiDxebUqdvvAhWbgP0HHYg5ATEQrAIoAHoECAQQAQ&url=https%3A%2F%2Fwww.toyotaownersclub.com%2Fforums%2Ftopic%2F39027-corolla-verso-w58811-headunit-removal%2F&usg=AOvVaw3mYwhK84HuJ6ydSvPrsjBU
found this on the forum don’t know if it will help also not sure if it’s applicable to your car. it looks like you have to prise the two side wing panels off that are next to the head unit (one either side) then I would try and prise the top vents out and you will probably see retaining clips/screws on top of head unit and under the side panels.
use a trim tool which are available quite cheaply on eBay go carefully and do not force anything some trim panels pull outwards some pull upwards.
2 hours ago, aj2021 said:
Thanks 🙂
Are not still in warranty, car had 5 years/100,000 miles
Hi, yes still in warranty but accidental damage is not covered by the warranty.
Thanks, have just bought the removal tool off eBay 🙂
  • 2 years later...
Hello , I have a Toyota verso 2017 and I can’t get to turn on the audio back on and have checked the manual but not help at all
