Yaris2015 Hatchback Ascent
Bella381
Hello,
My Yaris hatchback Ascent has done 50,000 kms on the clock and recently serviced to be told the water pump is leaking and needs replacing. The part is $500 plus labour.
Can someone please advise if the part would be faulty or other potential causes associated.
America, Canada or Australia ? - is this a main dealer ? find another shop asap
Can you PM me Your vin and i will look it up to confirm the correct part
Edit. Its a Australian model
costs are to much wich engine do you have???
As far as i can work out it's either a 1.3 or 1.5 - pattern parts down under seem very expensive nearly $300 AUD (about £140-150) Retail - genuine parts from Japan or the UAE $140-160 AUD delivered plus any duty on top
1.3 . I’m here in Australia.
I have had no joy with that VIN but the AU NCP130 1.3 and 1.5 hatch use the same water pump
1.3 - 2NZFE
Toyota Part number
16100-29157 Superseded by  16100-29158
Youre Yaris is made in JAPAN
I worked out the Frame number from the info the OP gave me (AU vin)
It's a JTD vin (NCP130- Frame No.) so Jap built for the AU market
