Yaris Engine Identification.
sproutdreamer
I am needing to order a new drive shaft complete with rubber boots and cv joint. Not genuine Toyota but just under £50 seems good. However I have hit a snag regarding the engine code.
On the vehicle registration it shows 1299cc and Engine no 2SZD238488 which I take to be engine code 2SZ-FE.
BUT on parts suppliers lists the 1299cc engine is listed as 2NZ-FE and no Yaris/Vitz only Yaris Verso.
Has anyone an insight into this-it looks as if the two engine codes use different shafts?
Can you pm me your vin, on a 04 in will be a 2szfe - does the joint need replacing
