Super strut suspension
Rauff
Hello everyone
I have recently bought a toyota celica t20 st202 gt as a driving project, and the bushing and links in the right suspension need a replacement. however my car has the super strut suspension system and i have a hard time finding parts that wont break my bank as i see them new as kits go for up to 2000 quid
any suggestions  :))
What parts do you need ?
Click to enlarge
Where are you located ?
Uprated polybushes
https://www.polybush.co.uk/polyurethane-suspension-bushes-components-products/toyota/celica-st202ss/
Track control links either Febi or Blueprint
arb drop  links are a common part so are cheap
The track arm is the expensive bit again Febi or Blueprint around £630 retail but can find OEM parts for £320
Edit. the full OEM kit for both sides £1400
hello again thanks for the messeges
i have taken the suspension apart and i found out i need a new bushing/arm as the one seen in the picture. and a ABS sensor for the superstrut system, so i dont need the full oem kit thankfully.
the part number for the bushing is OEM 48066-20061, and i dont know about the abs sensor
i live i denmark :))
Febi or Blueprint (Bilstien group) in the uk they are around £230 (2000 krone)
48066-20061 is for the Gen 7 1999 onwards (JDM import)
PM me your vin and i will give you the numbers
