I have a Kenwood KSC-SW11 underseat subwoofer that I am looking to fit into my 2008 Estima (ARC50).  There is a fuse box near the passenger size glove box which I can  take a 12v ignition switch feed from.  Wanted to check here if anyone has done a similar fit and if there is a better route I can run the 12v mains direct from the Battery and ground (or an alternative I can take these feeds from within the vehicle)?
I would be hesitant at fitting an amp to literally any potential 12v feed. The gauge of wire needs to be able to cope with the power drain of the amp.
Some Estimas come with an amp built into the head unit and some under the driver's seat. Can't offer any more than that I'm afraid.
