Celica radio removal
Peter Houghton
Hi there
New member here from Flintshire in North Wales. There's probably already posts on this, but I couldn't find them! How do you remove the Sony WX-C570R radio. Can't see any obvious fixings. The problem with it is only the cd works, and the volume is fixed at very low. No other buttons work......so basically the unit is frozen apart from the cd player. Not sure if is a simple fixable fault, or basically it's had it's day and needs replacing. Either way I need to remove it. Probably wouldn't want to replace it with anything expensive, as my Celica is a 2002 model with 246,000 miles on the clock........so any new radio / cd player could be worth more than the car!!!
Thanks, Peter
It's beginning to look like you're not going to get a reply on here, Peter.
Try asking on celica-club.co.uk
Hi Peter, essentially the front fascia pops off and there are four screws holding the headunit in place (a few more steps, but that's the gist 🙂
