Hi guys,
I have recently purchased an 2008 Estima in Australia, the person I bought it off advised that the right hand passenger door had the automatic opening function deactivated and the cabin only has a button for left hand passenger door.
The right hand side door however still does auto locking when closed, would it be easy to reactivate the right hand door to auto open and close? I wouldn't have thought that they would have removed the motor?
Any help would be appreciated with how to check if motor still in the door.
12 hours ago, Newmz89 said:
Hi guys,
Hello, welcome.
I don’t think there is an option to select and deselect within the system settings so would assume it have been disconnected within the door. Begin by removing the door card and checking the connections to the locking mechanism.
Then check voltage to the motor when the key fob is depressed.
From this you will be better placed to problem solve further if needed.
Quote
That reads to me as - The previous owner didn't want to fix it so just disconnected it as parts are expensive
ACR50 is an Estima
What year is it ?
Main power door switch - 84962-28010 (power door OFF)
Passenger power door switch - 84963-28010
Left and right controls in the courtesy light - 84963-28020
The side door sensor is on the door seal
RH door seal with sensor - 84250-28040
Door limit switch no.2 - C8460-28020
then you have 2 sensors for the slide half open
The main motor is on the door step - 85005-28060
Part numbers picked at random, so you can google, what the part looks like (mainly 2006-2008)
If you need exact numbers send me a PM with your Frame No.
Would it be from inside the door card where the motor potentially was disconnected? Or would the connection be on the lower track below the step up to the door?
As I took that off today to gave a look under there to see if anything was unplugged..
My model also has the door buttons near the side mirror controls,
Similar to below but the right hand door button has been replaced with a blank
Also strangely the keyfob doesn't have the right hand door button just a blank has been put there?  Wonder if this had been done prior to import?
Nothing up by the courtesy light ?
https://toyotastock.com/switch-power-slide-door-control-no-2-toyota-8496328020e0-1469367.html?q=84963-28020&p=1&nocat=0&g=%2Fsearch
can you see if the motor and belt are fitted ?
i would think it only has a power door on the passenger side
note - the big plug on the motor
https://toyotastock.com/motor-unit-slide-door-rh-toyota-8500528060-1475465.html
Pm me the frame number and i can look up the spec and give you the build date ect.
Looks like you are correct only has the one motor on the passenger side. I guess that answers my question!! I assumed they all had both automated.
How easy would it to be to install a motor and just have it hooked up with the door handle rather than switch up front?
Thanks for your help guys
It depends on if the wiring is in place and if you can get hold of the parts cheaply you only get power doors on both side and the rear on  the top spec models otherwise you're looking at 800+ AUD
Probably not worth it hey. Happy just opening the door manually hah.
