Distress
Giper
I need some help right away 99 Toyota RAV4 replace the o2 sensor now when I started up it runs match down on the gas and it cuts off what could be the problem
Moved to the Rav4 club.
Did you replace the correct sensor as some rav4's have 4 sensors, any other codes ? a faulty fuel injector will make the engine run rough and/or cause starting problems
