Door mirror unit
frankie406
Hi, just wondering can a auris mk1 door mirror unit be converted to a mk2 type with indicator light in it. My passenger side mirror is broke (just the black plastic surround) all works on it just the black plastic needs sorted but for quotes of £170 +/- for a second hand one is ridiculous.
Hi, thanks very much for your help.  Can this be modified to suit the 2010 unit with the indicators in the mirror surround?
Correct me if i'm wrong, but is this the correct part?
The price is not that bad.
I'm assuming the Auris is 2010?
https://www.atbparts.com/en/side-mirror-toyota-auris-2010-03-2012-12-electric-indicator-right.html
If the part is not correct, how mangled is the plastic on your unit? Have you considered fixing it, some epoxy to glue it, bondo on top, sand, primer, paint, and you're good.
Yes mate thats the correct 0ne and a great price. I will check that out. I could fix it. its not too bad but I'm selling the car and unfortunately the few people that has seen it has said about it although I did say I'll knock money off for it.
Got one £25 including post. Thanks for your input guys much appreciated.
sorry i used the 2006 from the profile thinking it was for the auris
