No brakes
Lovise
Hi, i recently bought an avensis 1,8 2004. The rear brakecalipers startet leaking so i replaced both rear brakecalipers. I have vented the breaks. When the car is turned off the breake pedal is hard but when I start the car the pedal is soft and the brakes dosent work. Any suggestions what the problem can be?
Sorry for bad English.
They need bleeding properly if you have ABS you may need a scan tool to actuate the ABS to get rid of the trapped air
