just after looking at the corrolla links, there is a bolt on turbo kit for my corrolla, how much is $2000 dollars in sterling these days?? :crybaby: anyone got this fitted? (id say the twincharged does?)
$2000 is a fair bit less than £2000. BUT you'll need to and import duties and taxes to that figure so you'll land up with it costing prolly a little over £2000 in the end. Then you'll also need to add shipping on top of that :thumbsup:
The are guys in the UK that regularly have stock of 3S-GTE engines (from MR2 turbo's). They might work out cheaper than importing yourself.
until you add the fitting costs and other sundries.if you want 3S-GTE power then put £6500 aside as a minimum
