Interior grab handle clips
Biggus
So... I'm now the proud owner of a 2009 Auris, and just noticed the interior grab handle above the driver's door is missing.
I've tracked down the part number of the handle itself (674683-8010) but i can't find anyone selling the clip required to hold it in place, or their part number.
I did find this series of helpful photos from a RAV forum tho; I believe it's the same as an Auris:
The last two pics show the clips I'm looking for.
Anyone know what they are or where I can get them?
The driver's side wasn't fitted with a grab handle.
As regards the clips, you could send Parts-King a pm giving your reg.no as a minimum and stating what you want, to see whether he can supply what you want
There are a few options
74612-52030-B1 or 74612-52030-E0
74610-52020-B1 or 74610-52020-E0 The clips come with the complete grab assist handle
the only ones i can find are for the sun visor 74336-52010 but look too small
That's a bit cheapskate! My Yaris had one, which I removed, and fitted a sunglasses holder in it's place (Chinese special that fits perfectly).
Does anyone use the grab handles.?  Do you Peter (mrjp).?
I admit, can’t remember the last time I used one.
27 minutes ago, mrpj said:
That's a bit cheapskate! My Yaris had one, which I removed, and fitted a sunglasses holder .
My Auris's had a sunglasses holder by the map lights in the roof lining.
No, not ever.:rolleyes: Hence replacing them (front, left and right), by glasses, sun or otherwise, holders with spring loaded cover hinges.
Well mine is certainly  "fitted" with the holes for one 🙂
On 4/23/2021 at 10:23 AM, mrpj said:
Is it only the steel clips you need?
I need the clip and the handle, but I raised the issue of the clips because the handles seem freely available but the clips do not.
Yes that is as maybe. I had two Auris from new (2009 & 2012), and where the 'holes' would have been, had plastic blanks in place.
Thanks for the advice peeps. I couldn't find one here in the UK and wound up getting a 74610-52020-EO from "Partsouk" here:
https://www.ebay.co.uk/itm/392331344139
they're in the UAE (!) but Fedex shipping to the UK was cheap (£16) and the handle slotted right in, so I'm a very pleased bunny.
