Fixable Sill Rot? T22 Estate
AF557
Hello, trying to figure out if the sill rot on my car is worth fixing. I really don't want to scrap it, and there's no similar ones for sale.
It looks like you need substantial welding assumiming the welder can get back to some solid metal to weld to. That particular area may be retrievable at a cost of £2-300 but if there are other areas going I think you are into scrapping it. It is quite hard to find body welders now in many areas.
The area shown also is the jacking point otherwise some GRP and body filler nicely sanded down and coated with underseal as we did in the 70's would give you another year or two before scrapping.
You used to be able to buy sills which were welded over but the MOT is very stringent about that now.
That's has been previously patched and the issue with the inner arch hasn't been dealt with you dont know what your getting in to until its cut out
A full repair sill is £55 the rest will need patching
i’ve already bought one spare chassis to cut patches for the front out, could probably get my uncle to weld them in
the rust goes a small bit under the car so welding isn’t going to be a dead easy job.
worst comes to worst this car’ll live out its days as a field runabout...
A man once told me "when its time to wheel a welder out to a car its time to wheel the car out to the field"
Lot of work needed there id say.
