I changed my 6 year old one owner Aygo last November for a new Aygo X-Clusiv. I'm a big fan of the model and very pleased with the new car in almost every respect apart from one. When the engine has warmed up, and not before, I get a sort of rasping sound under load. I don't think it's from the engine and feel it's more power train associated. As my previous Aygo was 2014 I hope that some modification has taken place to alter the engine noise and that my concerns are unfounded.
 I haven't contacted Toyota yet as it's only a mechanical noise and may be normal with newer models. Can anyone advise me please?
I had an aygo as a courtesy car while my auris was in for service a couple of years ago.
was shocked at how noisy the engine was under acceleration( as motoring journalists ) have said was ok once up to cruising speed on the motorway, maybe normal.
The Aygo is a 3 cylinder engine which makes a really nice throaty sound, yes, different to a 4 cylinder engine you may be used to. It’s a characteristic of the engine.
do you think it could be that noise.
Thank you for your responses guys. I wouldn't be concerned had my previous Aygo, an early 2nd generation one, made the same noise but I had it for 6 years and was never aware of the noise that this one makes. Perhaps the noise baffling was more efficient on my last one. Because of lockdown restrictions I have only done 1700 miles in this one and I have faith in Toyota for reliability and precision. I'll plod on and get used to it. I think the theory of a 3 cylinder engine is a great idea with bigger pistons, tougher conrods and bearings etc.
In October last year I swapped my 2008 model for a new 2020 model, I too noticed the very different engine noise.
Then I looked under the bonnet and saw a completely different inlet manifold and on doing some research found that the new models have a different variant of the 1KR-FE engine that has many differences:
- longer inlet tract that enhances torque
- 2 injectors per cylinder
- variable valve timing on both inlet and exhaust valves
- heated EGR system
https://toyota-club.net/files/faq/19-10-20_faq_kr-engine_eng.htm - look at the type '18 details.
When you take all of those into account it's really not surprising that the engine sounds completely different. I actually prefer the gruffer engine note under acceleration as IMHO it gives it more 'character'.
- heated EGR system
Dave
Thank you for this most comprehensive response. Clearly it has given me all the assurances I need. The amount of data via the link is incredible. At the risk of sounding crass, engineering has come a long way since my first BMC "A" Series.
Clive
  • 3 years later...
I have just bought a Aygo X automatic and am very disappointed at the engine  noise particularly when you put your foot down and it holds on to low  gear, do you think a sound deadening kit is the answer .
These cars has no gears as they are cvt and the noises under acceleration are because of the high revs that engine remains for longer time. Even non automatic small engine cars are always noisier than bigger cars with bigger engines for the same reasons, engine works harder at higher rpm to deliver the torque the car needs to reach desired speed.
The trick to avoid unnecessary high rpm and loud engine noise is to set certain rpm like 4000rpm and allow slightly longer time to accelerate. After practice this few times you will get use to it and notice that you lose one second in acceleration but gain better comfort and fuel efficiency.
  • Like 3
I have just done a 250 mile round trip on, the motorway and I am pleased with the way the x behaved
It never went over 4000 rpm I noticed you have to feather the accelerator to get the speed  required I was overtaking in the outside lane with ease 70/80 mph
I never had any noise problem going up hills on slip roads I was able to join the motorway as I did with the old aygo I think we have to change the way we drive to make it easier and a better driving experience
This kind driving and the problems described were also there on the auris 1.8 hsd.
If you use the throttle too much you get so much noise due to high revving and so little power that the combination feels not natural.
