Power steering pump
Exvec
84,950 miles .My steering appears to be getting slightly harder to turn ?Anyone had /got this problem.If so did you change the pump?and if you did was the stiffness cured .bu doing so.
Hy!
A bad pump is just one of possible causes. There are some videos about it I found.
Good luck!
Thank You Greg ,i'll have a look.
hi had this  problem on my avensis at  100,003 miles pump was ok and a new drive belt cured it hope you are lucky as well .
