Rav4 mk2 sunroof seal
Polmichy
I have 2003 rav4 that I am restoring for another long years to drive. I had a big problem with water leak through my sunroof. I cleaned all the drains, but during the stronger rain my interior gets really wet, so I ended sealing whole sunroof with a black gorilla tape. I found that the problem is the actual seal around the sunroof glass, but I can't find it where I can get a replacement. Toyota services told me they can order whole glass with seal, but that seems a little overkill regarding the price, which they quoted around £370
Does anyone know where I could get the actual rubber without rhe glass? Maybe someone was restoring their sunroof and have some advise?
Thanks in advance!
If you decide you need a new glass, you may still be able to get one from Amayama.com.  They may even be at reduced price to clear.
my sunroof frame had rusted badly under the seal causing it to bulge. I tried getting a new replacement seal to put on after threting the rust and ended up in the same situation!
I ended up buying a complete sunroof from a breaker (<£100 I think).
You can try sunroof/ glass fitters
  • Topics
  • Our picks
        • Like
        • Like
        • Thanks
        • Like
