Anyone who has an HKS SSQV will know it's got a bolt on the back that you can wind right in to stop it going off. Well i went to tighten this bolt but im a plank..used the wrong tool and now i've bent it and almost snapped it aswell.
Does anyone here reckon know if i can get a standard bolt from a hardware store or something ?
Should be easy enough to do. Even if it's snapped off, you should be able to drill it out and replace it with a new one if you're carefull enough.
Best of luck...
