Hi, I just bought a 95 2.2 lucida 2wd and like so many lucidas it has an engine oil leak. The leak is definitely coming from the cam cover. I see various prices on eBay for the gasket , is there really any difference in the quality? Is it a difficult job to do on the driveway? The A/C condenser is also shot any suggestions on a replacement.  Thanks.
3ct or 3cte ?
Toyota part number 11213-64060
Quality is very hit and miss, Victor Reinz are usually good quality, a dab of sealant in the tight corners before putting the new one on helps
There are 2 condensers listed the change over is 08/1995
88460-28240
88460-28420
They may cross ref to the same aftermaket part (not found a listing for one yet) but you may want to contact Nissens
Thankyou flash22 😀
