Brake Shield Cover - E150 SR180
Infiniti
Hey everyone!
Anyone know where you can get a hold of rear drivers side brake calliper shields for the SR180? I seem to find listings online for the front axel, however the rear appear to be elusive!
I have found one on eBay for £47, however I want to see if there are any other options before spending that much on a aluminium circle with some holes drilled into it!
Anyone breaking an SR180 with these parts available?
Thank you everyone!
The SR 180 is the 2.2 diesel isn't it ?
47881-12080
47882-12080
There are 4 different types for the auris 07-13 the SR has bigger discs all round so you need the correct ones (part numbers above are correct for the info  given)
